bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
Nice lookin B2,
31s will rub on the forward edge of the front fender when you turn, and they also require regearing, I put on stock 15x7 Ranger rims(deerfoot) with the original 31s but took them off after a week, truck was guttless at highway speeds, I put 235/75/15s on the same ranger rims and I like these, still noticablly less torque than the oem 215s at highway speeds but not too bad. I still needed 1/4" spacer plates behind the rims or wheel weights didnt clear the tie rod ends.
I doubt wider offset rims will help, it would only change the spot where the tire rubs, a lift would help on level ground but it would still be able to rub off road unless you cut the fenders out. Plus I didnt like how it drove with 31s, it tended to wander a bit in between the ruts of the highway, but with the 235s it tracks nice and straight. 31s will also put more stress on the steering linkage so that would need to be beefed up, and then the gears, even tho my motor is good and strong it really was lacking torque above 50mph, no power to pass anything.
I tried it, didnt like it, and dont care to spend the money I think is needed to make the 31s work, if your gonna do the work then do it first, then put the 31s on, but IMO... 31s simply do not work well on a stock B2. 235s work quite well tho, I live on a farm and drive in fields or pastures often, I hunt with it, and I drive 30k highway to work daily, it works well enough for what I need.
with a 2.8 and shitty gears i can see this opinion.
a ok running 2.9 with a manual trans and with 373 gears in a b2 will bitchslap 31's no problem.....if you swapped in a set of stock 410 gears or had 410 gears you would need 31's to haul ass on the freeway more comfortably.
with an auto the 31 in tire would be stressful with 373 gear but fine with 410.
345 gears enter a problem area with the auto but tolerable with a stick.
a great running 2.9 does fine regardless. a 4.0 will seem like a monster.
