Mikel89us
- Feb 23, 2011
Mill the head for compression. .125" is my suggestion.
As for the crank and rods, doing replace them unless needed. If no knocks are present, none of the journals will be bad.
If you are rebuilding it, replace all the bearings, a rebuild is worthless if you blow it up because a bearing fails. New pistons and rings. Buy speedoro pistons and perfect circle rings, both are cheap and reliable. If you want a motor that will last forever, buy moly rings, they last longer and don't wear the cylinders as fast as the stock style cast rings.
