skullandcrossbones
- Sep 3, 2014
I have a 1988 ford ranger with a 2.9 and a 5 speed. When i hook the battery up no matter how i turn the ignition ( even completely off my battery light never goes off) Well i have a feeling i need a new key switch cylinder any way because i dont need a key to turn mine. Could that be the problem? the battery light is on because i believe my alternator is out but either way should it be on even when the "key" is off? also my truck will not crank from the key (it used to without a key by the way) its not the solenoid or starter because i can start the truck by jumping the starter solenoid and it will run (with jumper cables mind you) so i was thinking maybe the new cylinder will fix it? if not do i need an ignition switch? (i believe its on the column close to the plug? i've replaced almost every sensor, i have to buy 2 vacuum lines tomorrow, new distributor cap, wires ,and plugs ( im chasing an idle issue, it seems to idle at 1,000 but runs so rough that it shakes the truck) i can plug up a certain vacuum port and it idles up to 1500 and runs smooth no roughness but way to high of an idle. the vacuum line that was on it broke so i think that may be why and so was the one on the right side of the emissions canister thing at the driver side front of the truck. please help? im more concerned with the battery thing than the idle at the moment though but i gotta wait till payday to get an alternator.
