my B2
dude, rig is awesome :headbang:
I'm planning/collecting parts for something along the same lines.
Q
What size rubber?
What is your wheelbase?
Inches from your tcase skid to the ground?
thanks :D
Q
What size rubber?
thanks :D
thanks
39.5x13.5 Iroks. 103.5" wheelbase. I dont know off hand but i want to say about 23" Im about to do a flatbelly so that should bring it up to about 24".
great job on the bronco, wanted to know what size lift the front TG leafs are and if you like them, I'm debating using them on my very soon to be sas.
both the front and the rear TG leafs i have are 3". I think they're pretty decent leafs.
how do you like the single ended ram setup, and was it worth the $?
looks like it could use some protection, it was already dragging in the video but otherwise a nice setup.
Works fine. Ive driven several other single ended ram setups so I knew abouts what it would be like. Definitly top 3 best things on my truck.
Doubler, full hydro, axles.
worth every single penny, not a bit of buyers remorse.
Ya it was hitting a little bit, but consider this. That was in soft sand/clay. Rock isnt going to suck my axle in like that. The ram is behind the diff cover and so high that it would have to be a pretty odd Rock to hit it. (plus it can take some abuse anyways). If the problem ever arises I'll address it.:icon_thumby:
didnt get a whole lot done tonight, but I got a decent start.
Ballistic order came in and I threw these on.
my B2
my B2
my B2
chopped the old remaining bed out, took off my Tail light pan and fue lines, air tank, ect.
Then cut out the base floor.
my B2
my B2
got a little more done tonight after work.
my B2
my B2
my B2
my B2
i like it...that should work good
so I know I usually work fast and knock stuff out but this bed project has been slow. Havent had alot of time to tinker but hopefully it will be done tomorrow. Here is the progress from this afternoon, about 3hours worth of work.
Finished welding skins in.
my B2
my B2
Modified battery box (adding lower foot tomorrow)
my B2
and the new Shock locations (already cycled suspension for clearance)
my B2
my B2
my B2
i like....nice work
thanks. here is more.
my B2
my B2
my B2
my B2
my B2
then you can see here, I welded the bolts in, and used wing nuts so there is no tools required to pull battery, thought it might come in handy.
my B2
shock mounts welded in.
my B2
my B2
should have it mostly tied up today, here is progress so far
my B2
my B2
my B2
my B2
my B2
