My 91 Ranger the stRanger
Does anyone have any info or links to tech on running toyota rear leaf springs?
Yeah that I know, I was more looking for how much lift an aftermarket leaf pack would give a ranger and if the toyota packs are shorter for shrinking down the wheelbase.
nmb2 has a great setup for low slung killer flex.
i am too heavy but i could add a few leafs and use similar.
Got the front end torn out. Tomorrow hopefully the new one is in
Been grinding the stupid rivets and drilling holes all day. I need some new bits to get any farther but here is some progress.
Got the arm mounts and coils temped in, I want to make sure everything is good before I drill holes and permanently mount the arms. Still need to make the track bar, panhard and fab up new crossmbers.
Drivers coil
Passenger coil
What have guys been running for brake lines? I was thinking either getting long lines to drop down from the coil bucket or a single line drop on top of the pumpkin and hard lines to the knuckles. Not sure if I can find lines long enough to reach from the coil buckets
I used them from the frame near coil buckets to the caliper.
Mine run hard lines down my radius arms with short lines at the heim and knuckle. If I had it to do over, I would put one in the center, the hard line it out the knuckles.
I think I am going to do that eventually but for now I made some lines work from the buckets down. I had the brakeware lines from before and duff steel lines, I combined them and they are plenty long.
I am hoping tonight I get the front on its own weight again. I decided to move the radius arms back a little from the pictures because it seemed liked the coils were bowing forwards. Then I need to figure out what I'm going to do for the rear. Most likely I boarding the springs
Ordering a bender today to build crossmembers, front bumper, and a bed.
The james duff kit looks real nice!! Looking good!
I know this is for the brakes, but if someone could please show me where the heck it goes, that would be great
on the caliper you have a little "I Beam" looking keeper for it....it goes between the caliper and the I beam....
hope that helps....
l8r, John
So it goes in the bottom groove of the caliper between that and the piece the bolt goes through?
it goes in the groove "hooked" to the I beam when sliding it in to keep the caliper....
you can just make out the end of it just above the bolt....
so it goes like this....
caliper
tensioner ( what you have in your hand )
I beam
caliper bracket
l8r, John
