mustang junk
nosrac04
Spanaway, Wash.
hello peoples, more questions. i just recieved an 8.8 rear end for free out of a fox body mustang. it is set up for the four link suspension system. quick quiz, i wanna know if this will fit under my 87 ranger. of course there will be some mods but i would like to make it work cause it was free. thanks
Other than it is a 4 bolt rear end and you will have to cut all the brackets off yup.
And the pinion is centered. That might cause a battle for space between the driveshaft and the gas tank.
Yeah, this is probably more problems than it's worth. Especially if it's a 2.73 R&P.
does this mean that it is more trouble than it is worth. i wanna run 4:56 and lock it up.
Hopefully you can find someone looking to swap out their 7.5 rear. The 4 cylinders had 7.5's as well.
2.73s.........don't do that....
I went with 2.94s.....and they're too lazy.....
you need a rear end at least in the 3.08 or higher.....
X 1,000,000
They are too high for a 302, let alone anything that came in a Ranger.
