Mustang 2/ P71 front suspension.
Ramcharger90
N/A na
Does anyone have any pics of what they had to do to their Ranger to use mustang 2 front suspension. I would like to build a chassis but if I need to cut the frame I'll just do it after the bent part. (After the radius arms) I couldn't find any in depth information on this or even The P71 crown vic suspension.
I wish I did. I've had a Mustang II for 30 years and was planning to put a suspension like it under my Ranger but the budget vetoed it. It would be worth investigating swapping a front clip from a 98 and up Ranger or an 03 or up Crown(with rack and pinion) depending on the width of the frames. A 91 or earlier Crown would have 302 compatible motor mounts but if you can handle swapping a clip you should be able to change the mounts on the later, rack and pinion front suspension. Good luck, please post pictures of what you do.
I will im not sure how or what im gonna do yet.
