(music help) Online Music?!?!
Boggin
Hey guys,
NONE of my music is working in Windows Media or LimeWire, when i try to play in Windows Media, it highlights it in orange with the little excalimation mark for every blessed song says it cannot play that file, when i try to play it in LimeWire it just says its playing but it isnt,
and yes, my speakers are turned up:annoyed:
and if it helps any i do have built in speakers,
so i was wondering 2 questions,
(1) What cold be causing this problem?
(2) Where are some sites that have music i can listen to until my laptop is done
(less than a week).
thanks
__________________
__________________
__________________
__________________
__________________
__________________
edit------
Just tried some online music sites, cant get anything, though the few i did find played there music using Windows Media Player, and mine isn't working so...
When WMP comes up with the little excalimation mark it normally means the file is missing or it was moved.
Go to the location of your music and see it the file is really there.
+1, and also, I use bearshare 5.2 and I like it. Haven't had a problem yet.
ok just restarted my comp and it works great now, thanks anyways, and i used to use BearShare, not no more though
another reason to want to be American:
Dear Pandora Visitor,
We are deeply, deeply sorry to say that due to licensing constraints, we can no longer allow access to Pandora for listeners located outside of the U.S. We will continue to work diligently to realize the vision of a truly global Pandora, but for the time being we are required to restrict its use. We are very sad to have to do this, but there is no other alternative.
We believe that you are in Canada (your IP address appears to be 24.222.228.196). If you believe we have made a mistake, we apologize and ask that you please contact us at pandora-support@pandora.com
i would ditch limewire...its not good 4 your comp
really? I used to have Kazaa Lite, then BearShare, now Limewire, I think I would like to go back to Kazaa
Man, that poor computer has gotta be FULL of spyware and viruses.
And it's even worse if you dabble in pirated software.
Giving out your IP address isn't helping, there could be some sort of "back door" someone could expoit as a result of installing crap software (or a result of what crap the crap software installs additionally), and could find it by simply scanning your ports.
Pete
Pete
that means, go back, edit, and remove it.
Jesus man, why do you hate your computer so much? I hope you have a good A/V and keep it updated and scan regularly. Oh and if you don't use it already, get Peer Guardian before you download anything else.
