High Desert Ranger
- Aug 8, 2007
- Age
- 51
- High Desert, Calif
My wife's computer is a Dell Dimension 4100. 256mb of Ram and a 40gb Primary HD and a 500gb Storage HD.
Not sure when the problem first started to occur. Could have been when I installed SP3 for XP.
My wife had decided to clean up unused programs off the computer and had deleted Quicktime. (A required components for iTunes). Then iTunes doesn't work and still doesn't. So I downloaded Quicktime from Apple only to find out that it requires XP SP3 so I downloaded that and installed it. Then installed quicktime. Then I tried iTunes and it didn't work.
Somewhere in there I lost the taskbar (No it is not hidden), the taskbar has a mind of it's own and 10% of the time it will reappear on restart.
Then I find that the Print Spooler wither doesn't automatically load or crashes during load. If you go to Services and manually start it, it works just fine till the next restart.
When trying to load iTunes I get "The folder 'iTunes' cannot be found or created, and is required. The default location for this folder is inside the 'My Music' folder."
I really want to get the Taskbar working 100% because it's freaking annoying.
All else is secondary.
