mason87ranger
- Mar 7, 2015
I have replaced FPR. I am getting gas out of the rail and it comes out pretty good. I would like to know if I am getting spark, would there be such a thing as me not getting a hot enough spark, that is coming from the coil. There was someone who asked me did I check my spark. I told them yes. They asked me what color was the spark. I told them it was yellow. They told me it wasn't hot enough, that it needed to be a blue spark. Never heard of that. Once again, I do have two new fuel pumps, new regulator, new fuel filter, the fittings on the return lines are smaller than the inlets so it would be difficult for me to get those crossed over. I did check the ohms on my injectors, all of them are around 16. I did use the NOID light, they do pulsate. When I got the FPR, the paper in it said it was set at 40psi. I do know that both of the fuel pumps are working. I put a temporary wire on them to test them to check for leaks and to make sure had plenty of pressure. I also went through the fuel lines from one end to the other, cleaning those out and also the tank when I installed the new fuel pumps and fuel filter. I do not know how to change the fuel pressure if for some reason I'm not getting enough but I do believe I'm getting enough. I do not know where to go from here. Any suggestions are greatly appreciated.
