royalmann
my daughters 1999 3.0 ranger had 225000 and was knocking so i bought a 2006 taurus motor with 60000 miles and replaced everything from the ranger the only think i did not change was the harmonic balancer. it starts but won't stay running. I have tried the cam synchronizer in every position and it runs the same i set the engine to TDC with the 0 on the harmonic balancer aligned with the timing mark on the timing chain cover, on compression stroke. I installed the sensor, using the alignment tool, at 38 degrees and i reset the computer by grounding the leads together when it is disconnected from the battery. it is not throwing any codes but it will not stay running i put a new fuel pump in. I can spray cleaner down the intake and it will run which continues to lead me to beleive it is not getting fuel and is pointing me back to the synchronizer can anybody help me?
