79Camaro
Quick explanation
My truck has been having more overheating problems, this time not that bad though. I thought it was the radiator, so I rented a pressure tester, which revealed that the radiator was indeed bad(few small leaks). I figured I would replace the water pump while I'm at it, as I didn't know how old the one on there was. Everything was going good(besides the belt tensioner not swinging) until the very last bolt on the water pump. With barley any pressure applied the head of the bolt just snapped off. It was one of the small bolts that broke. Being that it's not threaded into the pump I was able to slide the pump itself off. Now the threads just sticks out 1/4in from the block, How do I get it out? I tried vise grips but I can't really get that good of grip on it with it's position(under the A/C,P/S bracket), and I hammered a 5.5mm socket onto it but it just spun on it. I figured I would start a thead on here before I F'ed it up beyond repair. And to rub it in the old pump looks great and didn't even need to be replaced.
Here is a photo. It's one of the small bolts, on the far right(standing infront of the truck) near the lower radiator hose connection.
