rangeron33s
just finished putting together the 2.9 im about to put back in my truck. and i forgot which rocker arm pedistal shaft goes to the passenger side/drivers side! is it bad if i put the rong one on the rong side?! considering the threaded screws at the end of each rocker arm that sits on the pushrods? if it is bad how do i tell which is which? and if you cant tell how would i go about tightening or loosening these screws to make sure the valves and lifters are in the right sync. i dont want to get this motor in that im already going to have to adjust the timing on and just completely f*** the entire motor and snap the cam or screw anything up!
