I have an '86 302 thats a carburated motor, and i was wondering if the gt40 heads work on a carbureted motor and if I will gain anything noticable or if i'm gonna change cam later if a different head would be better?
For a good 302 with lots of torque run the GT40X heads. If you can't find a good deal on the X heads then go with the GT40P heads off an explorer or 93 cobra. Then run a trickflow stage 1 cam with a GT40 intake and you really only need 24lb injectors.. Best setup for tons of torque and descent power without breaking the bank. Whatever you do do not run the F cam. First of all it is designed for a supercharger or turbo and bigger cubes. I hated that cam and I had it on a built 347 with AFR heads and RPM II intake. Only reason why I got it was because I was going turbo.
So im takin it that I should tear my engine down put a new set pistons in an go from there?
