On the dana 35 ttb can i use the same u-joint to replace the middle one near the carrier as i would the outer ones (spicer 5-760x)??? Need to know if i should buy two or three when i do.
thanks
thanks
I don't trust front axle C-clip eliminators...
AD
does spicer have a greasable version of the 5-760x u-joints??? if so maybe wherever i end up buying them will be able to look it up.
so on the passenger side shaft running a spring eliminates the c-clip, further simplifying shaft changes and pumkin removal...
