MAP sensor (somewhat OT)
a31ford
Electronics GURU
Brandon, Manitoba
Typical MAP sensor (89 ranger 2.9 for example), I'm working on a project that will use a MAP sensor to trigger a timer on something that is NOT a Ranger.
Does anyone know the voltage output range of the sensor for vacuum read ?
OR can someone point me to a chart for the above ?
Thanks in advance.
Greg
Ford MAP(manifold absolute pressure) sensors don't output voltage they output frequencies in Hz
For your "trigger" you may want to use a GM MAP sensor which does output voltage.
Good read here on both, with charts: http://www.aa1car.com/library/map_sensors.htm
