koda6966
- Nov 28, 2007
- Automatic
screw it, I say get a c4 with a reverse pattern and a full manual valve body. Add a ratchet shifter and you can bang through gears faster than in a manual. The manual valve body with reverse pattern will make the gears go PRN123 and will lock the tranny in whatever gear you put it in and wont shift till you make it shift. The ratchet shifter wont let you shift into N-R-P while in forward gears.
Just an outside the box suggestion.
Since I can barely understand what you said do to my lack of knowlege, I think I'll stick with either the M50D-R2 or the T5.
