86_FX4
Hello,
I was hoping for some insight on potential issues with my trans before dropping everything and spending cash where it’s not needed.
I recently left for a road trip. Checked all fluids, everything was good. I felt like my usual shifter flop to check I was in neutral before starting the truck felt alittle different but thought it was in my head. We left for the road. About an hour into the drive on the highway, I couldn’t shift at all. Fearing the worst I pumped the clutch pedal and tried to shift with no luck, couldn’t get into any gear. A slightly audible “thud” could be heard when pressing the shifter against the gates trying to get into any gear but it just wouldn’t slip in at all. I had to coast to the side of the road, I checked under the truck, under the hood, fluids, etc, saw nothing of concern. I could shift fine with truck off, but not running. I put it into gear, then started the truck and started to make my way home, but then it was shifting and driving fine. So I took the risk and kept on with the road trip.
The same issue happened once again at a gas station, where I just could not shift into any gear. My partner thought she could hear a minor rubbing coming from under the truck in that case. I again just shut off the truck, put it in gear and took off with minor issues after that. At one point it seemed lurch unexpectedly once when I had clutch in but it was so brief and short that I again wondered if it was in my head.
The entire 5hr drive home, everything worked fine.
Any suggestions? My clutch fluid seems clear and has not dropped in level at all. Pumping the clutch does not improve the issue. The clutch feels slightly soft and disengages pretty low, about an inch away from the floor is when it starts to grab, but it has always been this way. Hoping one of you Ranger gurus has some ideas. I’ve had clutch issues before with other vehicles but it failed in a predictable way and was obvious my issue was worn friction plates, and in another case a bad slave cylinder… with this one being so dramatic and the way it’s acting makes me scratch my head and wonder if its something else. Are these master/slave cylinders known to fail like that or should I be looking at something more mechanical/internal??
Just as a sanity check today I took it out and did a fast clutch drop in 1st gear with heavy gas and the trans grabbed strong enough to break the tires free. So I’m confused. Help!
