MAF
RFD2
Arizona
Anyone know where to source a mass air flow for a 1986 2.9l ?
Nowhere.
Unobtainium.
Why?
An 86 2.9 never had a MAF sensor.
They ran a MAP.
Ok, then what is the component called that sits in between the airbox and the intake plenum? Is that referred to as the throttle body? It has what looks like a TPS attached to a throttle plate. It bolts directly to the plenum.
yes thats the throttle body. Itll have the TPS attached to it as well as a throttle cable, and 2 or 3 hoses running to the bottom side of it
