- Feb 28, 2024
- 3.0 V6
- Automatic
Well folks,
After learning that my truck in fact had a 4.10 axle instead of the door sticker's 3.73, I was absolutely befuddled, but assumed someone had simply changed the axle or the ratio in it's long list of previous owners.
After that I dug up the truck's build code, did a VIN lookup to confirm it was in fact a Dual Sport, all that checked out! So I thought.
Well today, I finally got the opportunity to put on my new summer tires. So imagine my surprise when I come face to face with:
I've been messing around trying to fix the truck's myriad of airbag codes, replacing disabled/burnt out bulbs, getting new keys, and installing power locks. I hadn't actually climbed under the damn thing. I didn't even have the opportunity when I installed winter tires, since the shop that was doing my mandatory safety mounted and installed them on the wheels the truck came with.
As I've mentioned before, this truck was in an accident at some point, and was put back together. It's been in this configuration for at least 8 years.
So, this truck's cab, and potentially bed originally sat on a Torsion bar frame. At some point, probably after the accident, it was put onto a regular coil spring 2WD frame.
I knew this thing was one of Frankenstein's creations when I bought it, it had a Ranger's airbag, mismatched front headlights, a B4000 fender on the driver's side, and a B3000 fender on the passenger, but I'm now painfully aware of the totality of the kludge that is this supposed Mazda B3000.
Thank you everyone for you advice on Torsion Bar drops, I hope what's been posted can help someone else down the line accomplish their own drops on their DS/Edges.
Forgive me forum, for I have sinned, and insisted on research before practice.
