chrisser
Finally got the heads and lower intake on the 2.9 and got the M5od and 1350 bolted back up.
While trying to sort out the trans wiring, I noticed that it looks like the trans case is touching the underside of the floor in front of the shifter.
I have the floor plate off, and there's plenty of room for the gearshift lever, but it's looking like I'm going to have to cut out part of the floor to get clearance.
Is this normal? I don't recall seeing this issue on previous swap threads. I'm using the (presumably) oem crossmember and mounts. Everything has bolted right up.
This truck originally had a 4 speed stick (FM146?) and the PO swapped in an automatic. I'm going back to a stick, but with the m5od.
