I have a M5OD from an exploder in my ranger(correct that, it's out on a bench). It has @ least 250k on it and it never whines. I lost 5th gear a while ago(10k). Within 25 miles after losing 5th, i drained the fluid and nothing out of the ordinary.
The shifter is all loose also, but had ford tell me they can't get the parts to fix these(couple wave washers,new pins and plastic cup). I think there's a rebuild kit for this I've seen on the trans tech page. Should ford still be able to supply these?
Gears and visible parts look fine inside. input shaft is quite loose in the bearing. Shifter was shifting into reverse and 5th, but only reverse worked. when I move the "ear" that shifts to fifth with the top of the trans off, there's noting there?
What should I do?
I've seen people say on the forum just to get a junkyard trans, but I can't find one.
What should I do?
