M5OD Hurst Shifter
Briansshop
MD
2.9 V6
Can you adjust the gate tension on the Hurst by removing the top and then some springs? I've read you can on the Core unit. Like the shifter,it's just a bit too tight.
Hard to find much, most people seem to bolt 'em in and go. I did find a post referring to 3/4 not having spring tension on it so maybe...
You can adjust the core? Thats what mine is and i didnt know
I am wrong, i did know. Its for setting the slack in the shifter assembly. There are two little bolts you adjust, one fore/aft and one l/r
Just screw on a bigger heavier ball for the shift-knob?... KIDDING! ;):sneaky: #HurstEnvy
PM me immediately if you get "tired" of the Hurst devil-shifter, and "need" to swap it out with the "mostly excellent" OEM shifter ordained by G-d and FoMoCo! :LOL::LOL::LOL: #HereToHelp ;)
PS: Good idea with the clamps--glad it wasn't "pre-loaded" to some crazy level where parts end up embedded in your drywall, lol...
