DasBaldDog
- Dec 10, 2010
Real quick question.
I believe that I have a coolant/oil leak being caused by a loose lower intake.
(See my other thread for more background)
All signs points towards (hopefully this is all) a vacuum leak on the intake manifold.
The question is this. The instructions in the tech library do not mention taking the upper intake off to tighten the lower bolts... but I cannot readily see a way to tighten them with the upper intake on.
Can the lower bolts be tightened with the upper manifold still attached or should/must the upper manifold be removed?
