Diamondback
- Jun 13, 2008
- Automatic
I'm working on a friend's '90 2wd with the 2.9L. The truck's been sitting for a year or so and wouldn't start. We noticed the fuel pump wasn't priming and the fuel gauge didn't work, so we swapped in a new pump/sensor assembly into the gas tank. We turned the key and the truck fired right up. We drove it a few miles, it ran like a champ. So, we came home and shut it off. A week later we tried to start it. Again, the fuel pump wouldn't prime (however, the gas gauge works now). Every now and then we heard a slight groan from the pump, but it didn't run. So, we broke out the volt meter. There's only 6V getting to the pump. There's also 6V at the inertia switch. We swapped in a new battery and still only got 6V. You can hear the relays click when the key is turned, just something seems to be pulling down the voltage. Do you all have any idea what would be cutting the fuel pump's voltage down?
