- Jan 6, 2008
- Age
- 49
- Armagh, PA
- Automatic
You're confusing the vacuum advance with the vac. secondary. The vac advance hose from the distributor plugs into the port on the pass side of the main metering block. That's not the vacuum secondary. The vacuum secondary pod takes the vacuum from inside the throttle body, under the venturis. Also when replacing the sec spring, it's also possible to get the vacuum diaphram out of place, blocking the vacuum port in the pod.
My distributor is a mechanical advance. But thanks for the info...I forgot about that.
So then what is the port on the bottom, front that is angled to the pass side?
