You should be running a much taller stall, a trans-brake will make a world of difference, reverse manual valve body if you wanna have even more fun
, I would say go to a virtual engine builder (as advertised in Hot-Rod, lol) and try to get your carb, and timing closer to match your combo... another thing to think about is that oddly enough sometimes combinations just don't work together.....
Aluminum heads can be had very cheap for a FSB nowadays as well.
If you needed all this back pressure to make power from small pipes, would drag racers really be using cut-out headers? no we wouldn't.
Frank
Frank
