Lost Interior Lights
Flint311
This is on my daughters '93 Ranger. The interior lights do not come on, the radio does not work and no lights, power mirrors do not work now either. Dash, headlights, blinkers, 4-ways work fine. She hit a bump while driving and that's when it was lights out. I checked fuses under dash and box under hood. Any ideas what it would be or what to check?
What I would suggest is getting a multimeter and making sure each of those things has power at the power wire. If not splice power in.
You've got the opposite power problems most do. There must be a power plug of some sort that came unplugged. Go hit some more bumps? Jump it! !! But seriously there are way to many variables to have a right answer.
I'm assuming youmean when you open the door there is no cab light. The cab light power mirrors and radio should all have power when key on. So that's a good place to start.
What all lights don't work?
Dome lights do not work. Dash/instrument cluster work fine. Was thinking a grounding problem or ignition switch wire. Either not getting power to the lights, mirrors, radio, OR somethings not grounded well. Thank you!
