danjil0
- May 21, 2012
Ok, This is a rebuilt 2.3l / 5speed. When I start it, it will run and pull fine. After you drive it awhile and shut it down for a few minutes (15-20), like going into the store, you fire it up again and it acts like it just won't take the gas. It seems like when you get to a little higher rpm, it runs better, but not right. No pick up to it. If you let it sit till it cools down, it will fire up and run and pull fine again. It's got me baffled. It does have the code for the purge circuit, but I was told that shouldn't cause my problem. Any thoughts or suggestions would be appreciated.
