Loss of power + water spot under motor.
98Longbed
So. Cal.
98 Ranger auto w/160k miles. Was driving truck and the radio went fuzzy like I was losing the station and then I lost power, engine died. Almost completely dead with only faint dashboard symbols. Thot maybe battery crapped so pulled and took to auto parts store. They said it wouldn't take a charge and gave me a free replacement. Installed battery and truck fired up, ram it around the block and it ran fine. Last nite I was out driving truck and same thing happened again. Completely dead. This morning I go out to see if it miraculously cured itself and I notice water has leaked (not leaking now) from the right side of motor close to the front tire and it's a decent amount. What could be causing my power loss/battery issue, same with the leak and do you think the water leak is part of the power problem or a different problem? Thanks again for the help.
i would suspect the alternator first, or possibly bad battery cables. the water leak is likely something different. the only thing i can think of that would make the two issues related is if the battery had leaked...
Update
Pulled the alternator and took for testing and it failed. Bought and installed new alternator. Need to get battery charged or get a jump to see if electrical problem solved.
