You can use a rubber freeze plug to block the port in the intake plenum. I believe the size you need is around 1 1/16. It has a bolt in the middle to squish the rubber to size.
The exhaust size is trickier if you want to do away with the tube...With my headers I stuck a bolt that was about the same size and welded around the head. I'm not sure how hard it would be with cast manifold.
And yes, the egr valve itself has a vacuum line running to it.
