Looking to replace Volt meter
adsm08
Senior Master Grease Monkey
Ford Technician
Dillsburg PA
31X10.50X15
Ok, so I want to ditch my factory idiot meter... I mean volt light... I mean... eh, you know what I mean.
Anyway, anyone ever seen a digital volt display that would fit into the position of the factory cluster spot for the 1st gen, non-tach volt meter spot? I've got a good idea of how to wire it up, I just need to find a display.
I have no clue... They are fairly odd shaped but if you want I got a clean one that I am pretty sure works... you could have... oh wait you want non factory...
Well i would personally ditch the gauges and stick an aftermarket tach in that spot and an aftermarket speedo in the speedo spot then get a pod or 2 for the other gauges.
I have no beef with my speedo. I have a tach on the column. I might go with the pods on the A-pillar for a voltmeter and oil pressure gauge.
