shanep1987
- Mar 19, 2013
- Automatic
2002 ranger edge 3.0, throttle body shaft seal is leaking. Anyone know what years are compatible with it? Or how to easily repair it?
If my memory is correct the throttle plate shaft is upstream of the MAF. If that's the case then I doubt any leak there would cause rough idle. I also think a 2002 should not be experiencing significant leakage there.
Just my thoughts to maybe save you going down a blind alley.
The MAF is upstream of the throttle body on every Ranger that uses a MAF. So a leaking throttle body will cause issues and taint the MAF readings.
