squealingtires
- Nov 6, 2007
- Age
- 43
'93 Ranger 4.0L Supercab 4x4 Running the Skyjacker lift with the extended radius arms. I had trouble fitting the 33x12.50 BFG Mudders mounted on 15x10 wheels w/4" backspacing so I convinced Skyjacker to trade out my 6" coils for their 8" pieces. Well, the tires fit turn-to-turn but the alignment has never been correct so I'm looking for some alternative solutions at this point.
I was a bit delighted to find that there are others running this setup. Does anybody have a near symetric alignment (my passenger side caster & camber are signifcantly more positive than the drivers side (with the same max adjusted alignment bushings) The alignment shop can get the drivers side to almost OEM specs but the passenger side is way out of wack causing a nasty steering pull.
What I'm interested in is any solutions/remedies that you all have found.
*edit*
I just found that there are some +/- 4 degree alignment bushings available on RockAuto
http://www.rockauto.com/catalog/moreinfo.php?pk=926039
When I look at this design, it appears to have 2 means of adjustment. Is it this way so that caster and camber are not 'locked' together (change one without changing the other)?
*/edit*
Thanks!
*edit*
*/edit*
Thanks!
