Looking at a 6.0 PSD
partsguy84823
Kansas - all over
Hey guys, I'm still in search of a super duty, and I have found one with a good price and fairly low miles that I want to go look at. Before i drive the 3 hours to see it, I was wondering if one of the Ford techs would be kind enough to run the VIN through OASIS for me. It is a 6.Leaker and I just want to see what kind of history it has had. (EGR cooler / head gaskets / FICM) etc...
VIN: 1FTSX21P15EB10383
Thanks guys. I appreciate it. You can PM me the results. And don't worry, I'm keeping the Ranger.
If it has a tuner/chip without a headstud kit, run don't walk... unless you want to have them intalled.
I know a lot about the 6.0s, I just don't know the history on this one. I know the shortcomings of the motor and I'm willing to deal with them, but I don't have the money to buy the truck... and stud it... and delete the egr... and rebuild the oil cooler... and install a bypass coolant filter on it... and be replacing a FICM that hasn't been flashed and could burn up at any time from cycling the spool valves for too long; all at the same time. I don't know if it has had a tuner on it, but if it has been a problem child I won't waste my time going to find out. If its warrenty claim count has been fairly low as far as the majors have been concerned I would be more comfortable buying this trucking and making gradual upgrades because this truck could be a great deal.
Standard Claims List For Model Year 2005
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSX21P15EB10383 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-OCT-2004 28-DEC-2004 123718 USA 3 3A15 0701XX 4C3Z 7G383 AA P69 41 6790
AWS Claim Key: 505078 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 03947 - * Name: CONLEY FORD, INC. Ph: 870-8562788 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:03-MAR-2005 Doc #:0190601
Cust Comments: CK FOR DELAYED ENGAGEMENT INTO REVERSE
Tech Comments: DIAG TRANS PINPOINT TEST CALL HOT LINE 5CCGJ024 CK PRESURE REPLACE PCA SOLINOID REFILL TRANS RETEST OK
1FTSX21P15EB10383 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-OCT-2004 28-DEC-2004 123718 USA 6 3M08 070303 * 7191 * L73 D8 11026
AWS Claim Key: 1187817 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03947 - * Name: CONLEY FORD, INC. Ph: 870-8562788 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:22-JUN-2005 Doc #:0204851
Cust Comments: REPAIR TRANS FLUID LEAK
Tech Comments: DIAG LEAK REMOVE CLEAN REINSTALL GASKET
1FTSX21P15EB10383 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-OCT-2004 28-DEC-2004 123718 USA 20 * * * * * * * 26469
AWS Claim Key: 5529848 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 08028 - * Name: MORLAN-SHELL FORD INC Ph: 417-2563193 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2006 Doc #:138536A
Cust Comments: PERFORM RECALL 05E15
Tech Comments: REPLACE DPFE SENSOR
AWS Claim Key: 5529849 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08028 - * Name: MORLAN-SHELL FORD INC Ph: 417-2563193 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2006 Doc #:138536C
Cust Comments: PERFORM RECALL 05B32
Tech Comments: ISTALL LABEL
Beat me to it adam!
