This is a little trick I saw off of PowerBlock. Get a spare key made, find a good spot under the truck that is solid, drill a hole though it, take a screw and wing nut and fasten that bad boy key in there.
i normally leave the windows down. keys in the ignition or in the center console. no reason to be locked out![]()
The antenna trick is a national secret. You have to go through a hazing that involves beatings, nakedness and a guy named bubba. Then you will be allowed into the inner circle of the antenna brotherhood.. Actually we dont say it on the open boards PM cammeddrz he will tell ya.
So all I have to do is beat, haze and see a guy name bubba naked?
I saw a guy in the walmart parking lot unlock his truck by throwing a green propane bottle through the drivers side window, pretty sure its was one of them redneck techniqeus you here about.![]()
Ok, here is the best way to unlock the truck...
Step 1: build time machine
Step 2: Go back in time to before you locked the key in it
Step 3: (And this part is important now) DON'T LOCK THE KEYS IN THE TRUCK!!!
