lock rite in a 8.8 trac lok
nossbud
i have the 8.8 trac lok in my truck now and i hate it. i cant keep spider gears in it for some reason. so i was wondering if i could just put a loc rite into what i got. cause isnt the open diff caseing different from the trac lok. thanks for any help
I dont think they make the lock-right for the LS case, they do make a no-slip for the LS case, its a smoother version of the lock-right. Or you could stick in an open case.
A lunchbox is any locker that takes place of the spider gears instead of a whole carrier, Aussie locker, lock-right, no-slip, quick lock and ez-lock are all lunchbox lockers.
thats what i thought so I DO know what im talking about. i do realize, lunch box no slip.
Yo,
Now aussie does not mention any restrictions based on carrier. Has anyone found this to be true?
Yo,
Well the carrier's are different, so an Aussie won't work with the LS carrier... A lunchbox designed for an LS case will need to be larger to fill the void where the clutches were. Really, an open carrier swap isn't too difficult, just use the same shims and races from the open carrier on the correct sides and double check the backlash and it should be good to go.
thanks guys for all the info. but one last question, for all the parts to fix my trac lok thats in there now its lik $250 and thats for new side and top gears, c clips, and the clutch packs is the trac lok worth it???
To me? No.. Off-road the trak-lok will slip like an open diff.
