live axle??
ithinkshesfat
can anyone tell me what a live axle is an how to tell if i have one?
it depends on who you ask. "live axle" is a term that has grown to describe a lot of different things.
most often its used to describe a solid axle, like that used under the rear of your truck. this axles consists of a housing, which contains 2 axle shafts (one for each wheel) connected to a center differential, which functions to allow one wheel to spin faster than the other (for better cornering).
Others will use the term to describe something like what is found in many go carts; a solid shaft for an axle without a differential.
I would think that live axle would describe a front diff that doesn't have hubs to unlock (spins all the time), like the front end of my 05 sport trac
And another opinion is a live axle is a drive axle verses a non- live axle as in front steering axle in a Econoline.
Sure thing, though I DOUBT yours has it unless someone switched it over.
Look at your front hubs in the center of the wheel. I have to remove a center cap to see mine but if you can see your lugnuts, look for a LARGE nut in the center. If you have that large nut, it is live axle. Ford went to that in late 2000 on Rangers.
If you have a plastic housing-looking thing in the center, it is the stock Pulse Vacuum Hub locking system, which is easily replaced with AVM manual locking hubs, if yours are bad. ~$120, IIRC.
