Stickers, lot of stickers I have a NOS one on mine (got that beauty from Wally world) Added about 25HP J/K. Just reg. tune ups. For most of the things I do the power is fine.
Not sure how Ford did it but the Mustang version of the 4.0 SOHC makes 240 hp, so there's more power in there somewhere.....
I don't know, but im guessing a different cam profile... The Mustang doesn't need low down torque like a Ranger does...
IF a filter change would actually allow MORE air (and hence more fuel) into the chamber... The engine would ping and clatter from too much compression!! (there can be NO arguement to this fact!!)
The result of this would be the computer would attempt to STOP the pinging.. which would result in retarded timing.. and even a richer mixture. So the NET result of MORE AIR would be worse performance.. Got that? Worse performance!
So all these ads for K&N and such are simply LIES!
However you are correct.. If it were possible to get more air you would then NEED more exhaust.. More exhaust without that "more air" is also a waste and MIGHT make the ride run worse.
Without changing the camshaft ANY modifications to the intake, heads, valve train or exhaust will result in zackly the same performance or perhaps WORSE.
Big JIm![]()
The stock system fills the chamber to the amount that makes the desired compression at spark. ANY MORE flow would make MORE compression! Which would them make ping... at the ping the system would then retard the timing and richen the mixture..
GOT IT! The cylinders FILL at every stoke from the factory! If they DIDN'T then ANY improvement would cause that dreaded pinging..
Even now just a little bit of carbon on the pistons makes these engines ping, so we know for sure any more AIR FLOW would do the same thing.
The existing intake flows far more air than the engine can injest.
Big JIm![]()
It is actually rated at 210hp also...
Sounds to me like you have drank the coolaid! If you think having more fuel in a cylinder than it was designed for won't cause PINGING and other bad things you need to think again..
No matter what the Ve is in any particular engine THAT Ve is what the engine was designed to injest! ANY more volume added WILL give problems!
The FACT that these problems don't exist after these so called "improvements" are added to our engines simply means there was NO GAIN!
Sure they are nice and bright yellow and red... but that is all they are, EYE CANDY!
You need to stop reading magazines that are PAID to write articles, and stop watching TV shows that are PAID to advertise..
Getcha a few books about how engines work. That would be a good start.
Big JIm![]()
Where are you getting your info? I would like to hear of an experience you have had, where you put a higher flowing filter on a truck and caused it to ping.
Well, I can defintely tell that someone in this thread has never worked on / tuned supercharged engines that add more fuel as the engine goes past normal VE.................
Bird
Big JIm![]()
NO!!! NO!!!! You got it all wrong!! The Tornado goes in the exhaust!!!
Big JIm
Wow more flow= worse performance. That's a new one. Sounds like you've done quite a lot of experimenting with the 4.0. You should open up your own performance shop and sell books on the subject so that more people can read your "fact filled" ideas. The whole world should be open to your vast knowledge instead of just this forum.
Just don't mimic the TV show you watched last Saturday..
Big JIm![]()
