Lincoln Lockers 10.25
ryanohn
Brighton, Michigan
So im doing a lincoln locker in my 10.25 semi floating rear for my 91 ranger. so im doing it in the next or so whats best way to do this removing the carrier or welding the carrier still in the axle ?
Remove the carrier and weld it on the bench.
As this is a semi float as you said make sure you dont weld the cross pin in place.
