Lifting my 2001 single cab 2x4 ranger
kooldude1292
Quebec, Canada
Hi everyone just looking for help as to lifting my single cab 2001 ranger.i think there was a posto n here last year that talked about brackets off a 4wd ranger that was an easy lift idea.
many ways to lift it, matters how high you want it?
1-3 in body lifts
lift spindles for the front
Taller Springs for front
Add a leaf in the rear
lift blocks for the rear
many different ways to go and i only listed a few
good luck and post pictures after you are done, would love to see the finished project!!!
As stated above there are several ways. A good safe way and not too expensive either, would be to just use taller coil springs and a rear add-a-leaf. I bought all of this on Ebay years ago when I lifted my 99 2wd Ranger. Never had any problems. Don't forget the front end alignment right away as well.
As far as I know there are no 4wd brackets that will fit on a 2wd 2001 Ranger. I would use lift spindles in the front and 4wd lift blocks in the rear.
