OK, I am thinking of replacing the older Skyjacker 4'/6" lift brackets for a set of Tuff Country brackets. A couple of reasons. Number one, is the bracket for the right side arm is in the way of the differential case, which at some point was notched for clearance. That bracket also seems to be cast... Number two is that it looks like I can adjust camber a bit with eccentrics with the TC brackets. My truck has a bit negative camber with the Skyjacker kit in the 6" position, and too much positive camber in the 4" position. Something in between would be nice.
Either way, I will be replacing the stock radius arms with the extended arms from the Tuff Country kit. But the bushing style trans crossmember is in the way, I will need to fab a replacement crossmember, unless there is a different crossmember from Ford that is tucked up better. I asked this question elsewhere and didn't get an answer.
I'm in the middle of a cab swap, so parts are easier to wqork on with the cab out of the way.
