Let's build a boat...
Here's the boat I renovate. B.O.A.T. "Bring Out Another Thou", but that's just wrong. Bring out another 5 thou.
If I had finished this for my trip to Panama, it would've cost as much as my house. I sold it and built my house instead.
1971 Irwin 32
63801
How about 5 PSI worth of love? :wub: Turbos and marine engines go together like fine wine and cheese. Mild boost won't get too hot for the engine bay and is apparently easy to tune if you have a Quarter Horse or something similar. If you have big gears on the drive you'll be able to run a pitch or two larger with both injection and boost.
If you want it this season, I have an EFI DP 2.3 head, dual plug DIS, upper & lower intake, throttle body & sensors, fuel rail, and a few misc. EFI sensors left over that I'd be more than happy to cut you a cheap deal on. I don't have the harness or computer however.
EXPLORENW:
I have the same or similar boat. Mine needs a few more hp. Mine is 1989 Bayliner Capri 1750 with 1978 Lima 2.3 I4 and Rochester 2JET carb and Mallory YS321CV distributor with points & condenser. Manual says it makes 120hp at 5400rpm, but pulling out a skier on one ski I only get to 3100rpm. Are the parts above still available? I live in Oregon.
  • Let's build a boat...
My 15' Carbon Fiber Allishot. 191#s with a Hot 90 Yamaha. 8600rpm, I have seen 80+mph
