Denisefwd93
- May 20, 2015
- South East PA
- 4.0 V6
- Total Lift
- stock, may get leveling springs in front "somday"
- Tire Size
- 235
The spindle is much tighter on the axle then the right side that came apart easily. the U joint is bad binds badly in one direction.
So....I took the left axle and spindle down the basement to clean and paint... spindle didn't want to come off... hmmm finally got brave and gave the back of the flange a few whacks it off it came. way way lots of a grease in there! The bearing seems good but still cleaning grease off. I'm pretty sure the grease was making it the axle turn sluggish and even holding the axle in tight.
Getting tired.. feeling a little bit abandoned by my old friend, may take the axles to the shop at NAPA have them do the spindle bearings and U joints. Taking the day off going to a boat club picnic. Glad I have all month to get this done right.
Question? Most of this front axle stuff only comes into play when in 4wd right? With the new Warn hubs the stuff will not be rotating; unless it's engaged right? I'm pretty sure it was all spinning when driving because of the bad auto hub on the right.
