mandospd
http://www.explorerforum.com/forums//showthread.php?t=171819&referrerid=30515
This was very helpful to me, particularly in deciding if I could tackle this myself...It was a piece of cake..I have been getting the lean codes and have been looking for vacuum leaks with no success and doing quite a bit of research, I feel that most people that post and swear up and down that it is the MAF or oxygen sensors or fuel pressure are in most cases on the wrong track, if your truck runs good and starts easily, yet, you get these codes particularly in cold weather, you should suspect the upper intake manifold to fuel rail gaskets. Also, I went to a Napa parts store, if you buy the Felpro MS 90733 it contains six gaskets, you will have three extra, it's about three fifty. this set is for 96-97 rangers, if your upper intake manifold is black and plastic go for it it...it will work.
