Leaky A4LD
94liftedranger
Hi guys my name is Sean. Lately i have been having a problem in my 94 ranger 4x4. Every day i am having to add more tansmission fluid because when i get in and put it in drive, i cannot keep it in gear. after i add fluid its fine until the next day. could it be a blown bell housing seal or freeze valve? any kind of knowledge helps. thanks
Is the fluid level actually down on the stick or are you just adding fluid till it moves?
Is it leaving spots where you park it? You are going to have to crawl underneath and see if there are any visible leaks.
