Latest issue with M5ODR1-HD transmission
gw33gp
Ham Radio Operator
Costa Mesa, CA
CA - USA
Other
2004 Bronco Badlands
Vehicle
Drive
1.5"
33"
I have posted before about an issue I have with transmissions popping out of 5th gear. I just installed a Zumbrota re-manufactured transmission that was a replacement under warranty. I seems they used the wrong gearbox housing. It is missing the right side (passenger side) upper bolt hole that is used for the 4.0 SOHC engine. I think the housing is from a 4.0 OHV (push rod) engine. So, I can only use 7 bolts instead of the 8 that my original transmission used. It has the two holes at the very top that are normally there but is missing the one hole on the right that is slightly down from those holes.
I am going to contact Zumbrota to discuss the situation. It was built in January and should be covered under warrant but I am tired of changing transmissions.
I didn't see it until I had the transmission fully installed. I really don't want to take it back out. Do you think I will have a problem with using only 7 bolts?
No - if memory serves, lots of people have interchanged OHC transmissions onto OHV engines and vice versa with no concerns related to the extra SOHC bolt hole.
Would not bother me. IMO Zumbrota is gaining a reputation for being kinda sloppy in my mind but I guess if you get a working transmission out of the deal, that's what really matters.
Yes, you are correct, it is a 1990-2000 M5R1 4.0l housing if there are only the 6 "block" bolts, 2001 and up have 7
But its odd your shifter fit, they must have used the 2001-2011 top plate and shift rails
Difference seen here: https://www.therangerstation.com/Magazine/January2011/M5OD-R1HD/m14.JPG
And I thought the OSS sensor(2001 and up) was at the rear of the main case, like in an automatic, not on the rear housing
No, I wouldn't worry about it, but for sure make them aware of it in case there is a future issue, or they want to swap it out
I did contact Zumbrota mainly to have it on the record in case there was a problem later. I just told them what I found, and the person I talked to was aware of the difference. I was told they would get a correct new one built ASAP and get it to me quickly. I told them I was not in a hurry to replace it and the transmission was working, so I was able to drive it. They said they would still prefer to get it to me ASAP because those housings were getting harder to come by and don't want to get it back damaged.
This will be the third re-manufactured transmission from Zumbrota. I hope three times is the charm.
I have a trip I need to take to Albuquerque in a couple weeks. I will just take it easy and not put to much load on it the bell housing, and hope it does okay.
Thanks for the replies. I feel better about using it for awhile.
Sounds like they’re stepping up to the plate, glad to hear it. 🙂
-Jazzer
Lots of high hp LS motors are being run attached to an th350/th400 without all the bellhousing bolts.. I wouldnt worry about it.
