Kyle M's Ranger Rebuild
Thats good news to hear....Glad you didnt have damage there :icon_thumby:
SVT
Good to see the brain is still alive.
Funds have been sent for stuffing my box. Thanks bro. :icon_thumby:
Yup, I was happy, figured it was trashed.
Thanks
Well, if things go good, I hope to start on the truck this weekend. plan is to pull the motor and trans, then do the axles, and frame repair. After that is motor and trans swap time.
Out with the old....
Sold and gone already too
Your build is so awesome I went through this whole thread!!!... took a couple days and I just looked at the pictures haha
Keep up the good work
Lol, lots of pictures I guess! Thanks
Well, I am half way done one my 1 ton swap, got the easier to put in 14bolt done. Just have to weld the pirches on after I get the tranny in and make sure it is how i want It. It is just tacked right now
Then i fixed the fubar in my frame. I cut the bad section right out
Then I made some new patch panels
Then welded them in, front and back
Then I made a template for a fish plate I am gonna cut out at work tomorrow with the plasma.
Thanks. I would like to one day, just depends on money. But to be honest, the leafs work, and very well too. They just look ugly and hang out the back a long way, but I have plans for that also.
Had a little garage time tonight, got the front axle out....I am no longer half ton lol
I also started on my wheels getting them drilled and tapped for the rings
Looks good so far....You planning on using those arms on the 60??
SVT
is the rings just to beef up the rims, or are you going to use them as bead locks ??
Robert
Just for strength and protection of the rim. I am planning on running inner air locks for bead locks.
Robert
The rock ring supports the lip of the rim preventing it from bending in and also helps deflect potentially hazardous trail debris and mung pung. Iirc he's running an airlock, its essentially an internal beadlock insert that utilizes air pressure to lock the bead against the rim. Sort of a 1/4 inner tube. You can run the lock at 100psi and run as little or as much tire pressure as you want.
