JimRummy
- Aug 23, 2010
- Age
- 39
- Los Angeles, CA
- Automatic
So after my kick down cable managed to wiggle loose, get dislodged, wrap around my throttle cable and almost cause an accident (and did kick my brakes ass) I have had to cut off the zip ties and re evaluate the whole situation. After having removed all the zip ties, I then decided to try and use some tubing around the cable, and held tight by some small zip ties. After setting it up this way I must say I don't like the way it feels, and it doesn't seem to kick down right. After using the tubing the pedal feels firm, and not in a good way, in a poor responsive way. I think the Kick down cable is the real issue. After removing the old zip ties I noticed that when I press the pedal the opposite way (toward the firewall {not the pedal itself, but the the one that actually attaches to the cable, behind the pedal) the cable has a ton on slack. When its pressed toward the firewall so it has no tension it has like a solid inch and a quarter to inch and a half of slack between the plug and spring.. Like the Accelerator needed 2 zip ties to take up the slack, and the kick down cable could probably take like 10.... Should it actually have that much slack ? how much should it have, because with the pedal in the resting position it seems like I could fit a whole nother spring back there..
Thoughts?
Thoughts?
