Just Plain Stupied
.Y E S ! ! !
(but don't tell blackwidow....I want it to be a surprise....)
yeahhhh boyyyyyy
btw the way dg, I already heard waaaaaaaaaaaa haaaaaaaaaaaaaa haaaaaaaaaaaaaa
Finally sbseee time. This is going to be good.
To make wrecking-crew happy just put in the good ol' SBC, paint the valve covers FoMoCo blue and stencil on a white oval logo. Problem solved :icon_thumby:
i vote for a more reliable and powerful sbf
but but he has that beautiful sbc sitting right there next to his truck.
36 ford and sbc are as american as apple pie
ahhhhh SBC!!! More PoWa!!!!!!!!1 WHAAAAaAAAAAAaAAA
I'd like to read you guys a quote......................HYENNAS !!!!!!!!!......................................
Just a bit of input.
Have you checked the timing?thanx for dbl-checking on me....yep....not only did i do the timing check(which was at 35*!!!), but i rotated the disty both ways to see if there was a sweet spot(which was at 20* with the shorting bar unplugged)
I found a eec/ecm/emc2 test book at the liberry....I'll test the ee...computer in the morning to see if it's fried....since all the sensors tested good yesterday....
Annnnnna ifa ita isa frieda..........S-aa B-aa Seeeeee-aa time !!!!!!(i speaka italian too)
But I will be depending (No... not DEPENDS diapers) on you guys to provide the co-rect motor mount part no.'s to make this as pai....brainless as possible to counter-act the V.A. drugs......Wa....no....seriously!!!!!!
im just sayin that to mess with blackwidow. i dont mind seeing a sbc in a ford.
Either way he should do that, dress up the SBC to make look like a FoMoCo motor:D
Yep.....the stragedegy...straydogey....thing is....to conceal the rear mounted distributor to trik the die-hard fomoco guys.....being from the New Orleans area, I figured one of these over the distributor would be appropriate:
;brownbag;
Then, to draw attention away from Da Bag....I would JB weld a fomoco distributor near the water pump by sawing the lowereererer part of the shaft off....
But first.....I;m waitin on some pics of sbc motor mounts installed, so the chevy part of my wittle brain can start processing the info.....
Pics please: (place here.....and hurry....i'd like to have this done by...ohhhh....yesterday afternoon)
EDIT: forgot tolog out again last nite!
you could hide the dizzy with a blower.:headbang:
:icon_bounceblue:i feel the need.... the neeed for Speed!
